2000 S500 needs leaves cleaned out. Advice?
Thanks!
Jeanne
Usually, there are a couple of panels covering the upper firewall area separating the engine from the passenger compartment which can be removed with minimal tools.
There is nothing much in that area that moves or is scary if that is what you are worrried about. The engine should be off adn the key in your pocket of course.
As with anything that is expensive and electrical, you want to be careful about arcing wires or connectors using metal tools as there are computers and relay modules in that area. For this job, fingers should suffice so that should not be an issue.
Make certain that the roof rail separating the roof from the doors is also clean. There is usually a drain there which can get clogged from organic debris. A strong spray of water from a few inches away will usually clear them. Close the hood before using water.
Thanks again!
Jeanne
You can access the other side of this hole by removing the glove compartment and pulling the two cabin air filters out.
Not sure if the blower motor will block anything or not though.
Thanks again!
Jeanne
