2000 A Class Battery Change
c class, a clasd
2000 Plate A Class Battery Change Without Setting Off Any unwanted lights on the dash. Time to complete 15-20 mins cost £40-60 diy
Ok battery under the drivers feet in a screwed in compartment.
Take a couple of plastic bags with you
Remove the cover to expose the the battery.
Remove the 10mm from the terminals and remove, I always place a plastic bag over the teminals for safety sake.
Remove the old battery, insert the new replacement and IMPORTANT put the head lights on (this caused a battery drain and prevents the engine managment light appearing after the battery has been chaged coming on savnig you £50 at a garage). Attach the terminals. Switch of the lights, replace cover and start your engine!
Hope this helps
Hope this helps
