ESP not available, dead throttle, CEL, limp mode
Old Nov 18, 2012 | 12:31 AM
JCH's Avatar
JCH
2009 C63
Driving close to home when car shudders, decelerates to about 3mph, and throttle pedal goes dead. Display says ESP not currently available, yellow triangle stays on as well as the cel. Managed to limp home although crossing a busy intersection at 3mph with flashers on was exciting - barely made it before the light changed.
Just got the C back from the dealership last night where they fixed the leaking intake manifold gasket,changed the oil, and replaced the two rear tires. This is what I asked them to do. However, after the incident tonight I read through the work order and see that they also found the right rear axle side seal leaking and replaced it under warranty. Funny the SA never mentioned this, but whatever. I'll have it towed back to the dealer on Monday, but I am wondering if they somehow botched the rear axle side seal repair and triggered the ESP problem. In reading the work order it appears they had to remove and replace the right rear axle so it sounds like it involved a fair amount of work. I also noticed earlier today that the rear end slid a bit to the right once or twice (ESP was on) when accelerating around curves, but didn't think much about it until tonight's incident. I've had the ECU flashed (couple of years ago) so I'm hoping the rear axle work is the culprit and the dealer can remain ignorant of the reflash. Tried the ECU reset procedure, but no change.
I'll post the resolution next week after the dealer repair.
Thanks,
John
Old Nov 18, 2012 | 12:01 PM
esp's Avatar
esp
2005 mb sl55 amg
power loss after renntech upgrade
i'm new to forum and would like to know if anyone else have exp, this. I recently did renntech package 1 upgrade on my 2005 sl55amg, after running hard, i'm experiencing loss of pwr and it comes back after a few seconds..has anyone had this exp? ..pls advise..
Old Nov 18, 2012 | 02:25 PM
awiner's Avatar
2003 CL55 AMG
Have them read the codes being thrown. It will narrow down the issue which I am certain is related to the work preformed. Possible sensor related.
Old Nov 19, 2012 | 08:34 AM
esp's Avatar
esp
2005 mb sl55 amg
thanks adam, i will certainly look into it...will let you know the details when done...
Old Nov 20, 2012 | 10:54 PM
JCH's Avatar
JCH
2009 C63
Turned out to be a loose rear throttle body connection by mechanic who replaced the leaky intake manifold gasket under warranty last week. Crap happens. Seems to run fine now.
Old Nov 21, 2012 | 09:06 AM
esp's Avatar
esp
2005 mb sl55 amg
glad to hear, hope all's well..good luck!!!
