1984 5 cyl diesel injector torque values
Old Jul 30, 2003 | 06:21 PM
marangio's Avatar
300 cd
Wink 1984 5 cyl diesel injector torque values
hi, im in need of the torque settings for the injectors and the pre chamber retainers. any help? thanks!
Old Aug 1, 2003 | 05:11 AM
Steve Clark's Avatar
C32AMG
The pre-chambers are torqued to 150 to 180 Nm,and the injector torque spec is 70-80 Nm.It's best to have a manual for reference, and a few special tools are needed as well.The pre-chamber installation procedure needs to be done by the book!.If you've resurfaced the head,a thicker pre-chamber sealing may be needed also.
Old Aug 1, 2003 | 03:12 PM
marangio's Avatar
300 cd
thanks steve! i have made the special tools and they work great. one problem, is the last person that worked on this motor stripped out the hole for the prechamber retainer. i may have to pull the head to get it repaired. thanks again!
Old Aug 2, 2003 | 02:35 AM
C32AMG
Good luck!
If you're going to have the head torn down again for the pre-chamber repair work,why don't you do some basic porting and manifold matching while it's disassembled?.Should make a noticeable improvement.
