1997 e320 Antenna Wiring Question
Old Aug 18, 2003 | 01:58 PM
GeneR's Avatar
Question 1997 e320 Antenna Wiring Question
There are 2 coax cables in the rear left wheel well. One is for the integrated cell phone antenna and has a mini-UHF connector. What is the other coax cable with the FME (nipple) connector intended for, and where is the other end of the cable located? I can't find anything about it in ALLDATADIY ?
Thanks!
Old Aug 18, 2003 | 03:18 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Re: 1997 e320 Antenna Wiring Question
Thanks!
I believe it goes to your center armrest console, where the cellular phone is connected to the antenna cable. With the phone installed, a compensator goes in the wheel well, thus the break in the cable. The FME connector is fitted with an adapter to convert to male Mini-UHF. The compensator (actually, for 1997 it might be a 3-watt BOOSTER instead) is fitted with two female Mini-UHF connectors and completes the antenna connections.
-s-
