ML 350 BAS\ETS ABS BRAKE LIGHT ON
I HAVE A 2005 ML 350, SATURDAY AT THE MALL MY BENZ DIDNT WANT TO START, LIKE THE BATTERY WAS DOWN, I GOT A JUMP START, EVERYTHING WAS FINE, NEXT MORNING WHEN I STARTED IT THE BAS\ETS ABS PAD WEAR AND BRAKE LIGHTS ARE FLASHING AND IT WONT COME OUT OF PARK. WHEN I TURN THE KEY AND PUT IT IN NEUTRAL, START THE BENZ, PUT IT IN DRIVE IT WONT SHIFT OUT OF 1ST AND THE ABOVE LIGHTS ARE ON AND FLASHING, I TRIED TURNING THE WHEEL FROM LEFT TO RIGHT TO RESET THE STEERING SENSOR. REPLACED THE BATTERY. JUST LIMPED IT TO AUTO ZONE TO PULL UP THE CODES. IT GAVE A P0270 AND A BAD CONNECTION CODE, UNPLUGGED THE ODB WAITED A FEW MINUTES. WE DIDNT CLEAR THE CODES BUT NOW ALL THE LIGHTS ARE OFF AND EVERYTHING SEEMS TO BE OK? IM WORRIED THAT THEY WILL COME ON AGAIN?????
Replacing the battery, and cycling through the relearn usually resolves all the issues.
whunter@pelicanparts.com
