1985 380SEL Smokes and fuel smell
Old Apr 1, 2013 | 11:01 AM
mbclassics's Avatar
Any ideas are appreciated. Car has only 100k miles. Compression is good at about 175psi on all 8. Noticed cylinder #1 spark plug is wet with fuel. Has spark and injector tested fine. While running I pull the plug wire (on #1) and makes no differnence in running. All other spark plugs are very black. Car smokes alot when running and smells like gas from exhaust.
Old Apr 11, 2013 | 10:16 PM
PelicanParts.com's Avatar
SPONSOR
Hmm
If it still has the factory ignition coil, I suggest you replace it.
A weak (dieing) coil would be the cheapest issue/answer.
whunter@pelicanparts.com
