2004 MB C240 cold start problem
The 2004 C240 has only 45K miles and all the regular services were performed as required.
I have been having an extreme problem starting my 2004 C240. The morning start, it would crank and crank, and won't fire up. After quite a few attempts to start the C240 and when it seems to want to fire up, it sputters. After a few more time of trying to start the car, it eventually fires up. When I do get the C240 started, it runs beautifully.
Recently, I have done the following trying to fix my starting problem:
changed car battery.
complete tuneup (replaced plugs, oil/filter, gas filter, transmission fluid, coolant, brake fluid, air filter, and the cabin filter).
replaced the crank position sensor and cam sensor.
Prior to this problem with starting the car, the check engine light came on and the car had a problem with Mass Air Flow (being dirty). The mechanic cleaned the MAF and the car ran beautifully for over 3 months. Then, the cold winter came and my car started to have problems starting up in the morning. The car will crank and sputters when it tries to fire up. Even after doing a major tuneup and replacing the sensors, I am still having a problem starting up the car. BTW, the car is always garaged.
The strange thing is, when I do manage to start the car up, it runs beautifully on the road and freeway and the gas mileage is normal. I can even shut off the car for a hour or two and it will start up right away. And this includes multiple times shutting off the car and restarting it. Please, can anyone offer me any good suggestions to address my problem with starting the car. I really need help and any suggestions will be greatly appreciated because I am very worried about being stuck on the road.
I have asked my mechanic to think about cleaning out the throttle body to see it that will help. When I asked him about the fuel pump, he told me that's very unlikely because the C240 runs beautifully on the road and freeway. Another thing I am thinking is to have the MAF checked again. I have also read a post that mentioned the relay may need to be checked.
I forgot to mention that the mechanic also mentioned to me that when he serviced my C240, the throttle body didn't look dirty. The C240 was rechecked with a diagnostic machine and nothing showed up.
A long cranking situation quite often indicates a drop in fuel pressure as the vehicle sits over night. After cranking for a while, the fuel pressure should have been able to build up and run normally.
First things first; Verify that you have good fuel pressure.
My mechanic just finished checking the fuel pump's pressure and it is normal. He is going through and checking the voltages in the car. At this point, my mechanic is going through the car looking for the problem to fix the cold start problem. Any suggestions are greatly appreciated. Thanks.
After weeks of testing the voltages, my mechanic is convinced I do have a problem with the fuel pump. He told me not to let the car sit and to drive it every day, until I get the fuel pump replaced. So, when I start the car, I would just turn it on for 10-15 seconds and then crank the car to start it. Works like a charm and without any problem starting. I personally want to thank you for the excellent advice. Thanks a million....Morris
Hope this helps!!!
Hope this helps!!!
Hope this helps!!!
btw, I had the mechanic replaced all the fluids, plugs, and filters. even replaced the CPS and CO sensors.
Last edited by mlee1951; Dec 29, 2013 at 02:07 AM. Reason: 2004 C240 cold startup problem in the morning
Btw, the Crank sensor and Cam sensor were replaced during the full major service (all filters, fluids, plugs were replaced). Initially, I had the battery replaced thinking it was long overdue and wasn't getting enough juice to fire up the engine. But, that was not the case. Good luck.....
I then took it to the Mercedes Dealer. They decided it was the Mass Air Sensor. It was reading 0 degrees, when it was actually 28 degrees outside. They replace the Mass Air Sensor.
Took the car home. The next morning wouldn't start. Car got towed to the MB dealer this morning. Stay tuned......
The only way the Mercedes dealer could see the problem was to look at the temps from the Mass Air Sensor that the ECU was reporting. It was showing 0 degrees when the outside air temp was 28. With the Mass Air Sensor disconnected and shorted the values were also way off. The dealer had a special computer to see these values, that other mechanics don't have.
Note: This was NOT cheap ($1,400 part).
Hope this helps!!!
Can an independent German mechanic shop "reprogram" the C240? I guess "reprogrammed" means a software update.
BTW,
one C240 owner, who has a cold start problem, the dealer changed the Engine Control Unit (expensive). :-(
Thanks for the advice.
