Lamp defective light?
Old Sep 2, 2003 | 11:36 PM
darkstorm's Avatar
'98 clk 320
My gf's clk 320 has a "lamp defective" message on all the time.I did re-place a front marker light however,this message keeps coming up.It reset itself for about 45 minutes a month ago however,it is always on now.Any suggestions?
Old Sep 3, 2003 | 06:17 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
you need to check all the bulbs (burnt) and their sockets (corroded). All means: front markers, hi beam, low beam, fog lights, corners, rear lights, back up lights, all 3 brake lights, corners, fog light and license plate lights.
Old Sep 3, 2003 | 08:12 AM
darkstorm's Avatar
'98 clk 320
Will do,thanks Bam..
Old Sep 3, 2003 | 04:08 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
When You replace a Bulb..You MUST Install the Same Bulb(Watts) or the the Bulb Check lite will come on.
Also Inspect the REAR taillite bulb holders..They MELT..Cheap Plastic! I have Seen Several Melted
