Thermostat replacement, 2007 R350
Should the thermostat be replaced by the dealer or is it possible for the owner to do the work?
Start out by draining the coolant at the radiator.
Detach upper coolant hose from the thermostats housing.
Remove poly-V belt and guide pulley.
Unlatch electrical connectors and disconnect.
Remove the two bolts.
Pull thermostat out and install in reverse order.
