Winter question
Old Nov 17, 2003 | 09:19 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
Winter question
hey all,
Now, I know when you start driving after you started up the car, your suppose to be gentle until the car is fully warmed up. BUT, in the winter, going out my driveway can sometimes be tricky when there is snow out there and I get stuck, so I have to rock back and forth with high revs to get the car unstuck...all of this within 5 minutes of starting the car.
Is this bad for the engine? I always take it easy until the temp guage registers, but this isn't the case in the winter...so what should I do? Thanks.
-G-
Old Nov 17, 2003 | 01:03 PM
MercManiac's Avatar
2004 S 600
As long as you have synthetic oil in the engine you'll be just fine.
Old Nov 17, 2003 | 06:57 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Nope, no syn oil. '94, I'm using Castrol good old dino oil. Dealer said with the age of engine, the syn oil may find tiny places to leak out of (if there are seeps or cracks) because the oil is so thin...but if i let it warm up for a lil, should be ok?
-G-
Old Nov 18, 2003 | 12:59 AM
pointman's Avatar
a car that can't do the throttle reset.
cool... just curious but why does synthetics make a difference in that situation, thanks.
Old Nov 18, 2003 | 09:58 AM
Lynn's Avatar
Synthetic oils don't thicken nearly as much as regular oils in cold temperatures. Therefore, it is much easier for the oil pump to pick it up out of the sump and distribute it through the engine immediately after the engine is started.
Old Dec 6, 2003 | 11:58 AM
suntubi's Avatar
e320 2000
Red face Suggestion from snow country
Take 5 - 7 more minutes to warm your car before going out in winter ( particularly if it is cold) and by all means don't rock your car at high revs. I'd worry about the drive train rather than the engine.
Take it from a guy who grew up in Buffalo -- rock slowly and when in doubt shovel under the car! Keep some bags of water softener salt in the trunk if the roads aren't kept clear in the winter or if you get stuck. Weight and traction. Be sure to keep the salt well contained and get it out of the car as soon as spring starts.
