Where's the fuel filter??
Old Nov 20, 2003 | 08:20 PM
mb-mopar nut's Avatar
97 e420, 81 240d, 87 190-16v, Dodge Cummins Diesel
I have a 97 E420. Pulled panels off everywhere, can't find the pesky fuel filter. Also, I need to know the location of the pressure relief valve.
Old Nov 26, 2003 | 09:17 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
I am not completely sure for the W210, but I guess it is located in the same area where it is in the W124 series. At least its worth a check. It is underneath the car, rear passenger side, behind a plastic panel together with the fuel pumps, filter and backflow valve (attached to the pump(s))
Old Nov 26, 2003 | 11:39 AM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
mb-mopar nut, did you check yet to see if it's there??? I'm curious as well...
Old Dec 6, 2003 | 01:35 AM
haven't had a chance yet. My old 240d went down so I have to give it some TLC. I did pull that panel off originally (3 screws hold it in) but I got confused, the pump looked like it was in a sealed plastic thingy so I got nervous and didn't pull it apart.
Old Dec 6, 2003 | 10:13 AM
suntubi's Avatar
e320 2000
It's there - trust me
Standard placement for the fuel pumps, filter and accumulator is passenger rear, near axle, under plastic shield. Be careful to replace all mounting straps correctly to avoid bimetal effect and also the engine manual instructs one to replace all sealing washers after changing out filters or otherwise loosening fuel lines. ( they are cheap but essential.)
