1999 Clk430 wont go above 25ish PLEASE ADVISE!!
Old Apr 26, 2014 | 03:13 PM
jamiedbelle's Avatar
1999 clk439
1999 clk430 150,000 well maintained. A few mornings ago when I tried to start my car it started then turned off two different times before it finally stayed on. it did that again later that afternoon when I left class. Then,that evening I was driving and out of nowhere it just felt like the engine switched to a lower gear. I pulled over and put it in park,then took off again.But she wouldn't go above 25 or so. I'm not mechanically inclined, so its hard for me to describe this.Does anybody have an idea of what might be wrong? Approx $$?
Old Apr 26, 2014 | 05:03 PM
hillcreative's Avatar
2011 E350 Cabriolet
Sounds like the car is going into limp mode. You need to visit a dealership to determine the error codes before you know what kind of repair.
Old Apr 27, 2014 | 06:43 AM
mohd.awaly's Avatar
mazda mx5
Sounds like a bad fuel pump .. it might be pumping less fuel than needed and causing the lack of power
Old May 15, 2014 | 02:20 PM
marc hanna's Avatar
2023 GLK250, 1987 560SL
This will also happen if you put lower grade fuel in there. The knock sensor will detect pre-ignition and go into limp mode.
