electric cooling fans ml320
Old Dec 4, 2003 | 07:23 PM
SDML320's Avatar
Talking electric cooling fans ml320
I am new to the MB world and to MB vehicles I use to buy Audi's. Anyway I bought a 2000 ML320. MY question is if the cooling fans on the radiator should turn on when I turn the air conditioning on. Mine don't or does it have something to do with the temp here being 30 degrees outside. i have never had a car that the fans didn't start when the air was switched on. I would like some input on this because the warranty runs out next month. Thanks
Old Dec 4, 2003 | 09:40 PM
f4i 954's Avatar
2009 e class 2012 ml350
Check your fuse.
Go to the ML forum & chec under auxillary fans dead.
Old Dec 5, 2003 | 02:41 AM
patrick's Avatar
Audi's and MB's are not the same!
On Audi's the AC cooling fan turns always, on MB's they are switched by pressure and temperature.
Old Dec 10, 2003 | 06:36 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
.....and dont forget the fan in front of the "radiator" (actually this is the condensor of the A/C which you see) are just the additional fans if A/C is on, and not the engine cooling fan which sits inside between the engine and the real radialtor. The aux. fans only come on when certain pressures (A/C) and temperatures (coolant) are reached. And its not like the AUDI's and VW which turn on the fans even when the car is parked, and scare the hell out of bystanders. :-)
