2003 ML350
Old May 27, 2014 | 02:05 PM
jetter600's Avatar
ml350
2003 ML350
Hello,
I have a 2003 ML 350 with 266,000 kms. I am located in Vancouver Canada.
The problems I am having with my ML is as follows:
Stop at a light or idle after the engine has warmed up and it runs rough. The idle drops from 650 RPM to below 500 RPM and hunts up and down. Apply throttle becomes OK.
Here is what I have done so far:
Replaced the Mass airflow sensor, the forward 2 oxygen sensors, the throttle position sensor.
I have also checked for leaks in the brake booster in case this was causing a lean mixture by have a hole in the diaphragm.
What else could it be? Please advise.
Old May 28, 2014 | 09:05 AM
mohd.awaly's Avatar
mazda mx5
it might me a bad coil , best thing to do is check for fault codes , erase those codes then test drive it again , then read the fault codes , it should point u in the right direction ...
Old May 28, 2014 | 09:20 AM
jetter600's Avatar
ml350
Thanks Mohd. I will try that. If there are any other ideas I am open to suggestions. The rough idling it getting to be a problem as the outside air temperature starts to get warmer out here.
Old May 30, 2014 | 10:32 AM
jetter600's Avatar
ml350
The igniter did not help. ML still surges during idle when engine warmed up. Any more ideas I can try. Please help. Thanks.
Old Jun 16, 2014 | 09:46 AM
jetter600's Avatar
ml350
Can someone help me with this please? Having same problem.
Old Jun 16, 2014 | 09:54 AM
mohd.awaly's Avatar
mazda mx5
Might be carbon build up in the throttle
