07 C230 Sport misfiring low RPM
Old Jan 8, 2015 | 03:47 PM
Les0913's Avatar
2007 C230 sport
07 C230 Missing bad but clears after re-starting it
Hey guys. Hoping I can get some help with my problem without using trial and error as a repair technique. I changed the plugs a few weeks ago because the car has 110k miles on it. I used Autolite Iridiums so hopefully that's not an issue. The day after I changed them, I floored it to pass a car, the check engine light started blinking (yes, it was already on) and sounded and felt like it was running on 7 cylinders. After a few miles I stopped and shut it off for 5 min and started it up and it ran smooth for awhile, then it happened again. If I keep the rpms up its fine but as soon as I start slowing down to come to a stop or slow down in traffic, the light will start flashing and it starts missing bad. If I manually downshift or put it in neutral to keep the R's up it runs smooth. The codes that it put out are 0301, 0331, 0410 & 0351 which one or more might've already been there from before I changed the plugs. I've heard that it may be vacuum lines broken, fuel regulator bad, throttle pos sensor, crank sensor, coil packs and a few others. Since the 0410 code is secondary air injection system fault, is that possibly vacuum issues? Any help before I take it into the dealer would be very appreciated by me and my wallet. Haha. Thanks in advance to whoever tries to help out. This is the first one I've owned and I'd hate for it to possibly be the last one. Thanks again.
