So i washed the engine and lots of check lights are coming on! C218 CLS 500
Im hoping someone here knows a trick to this, or else im afraid its going to be expensive!
To start, there are no error notifications on my 2006 CLS 500.
I washed the engine bay with a light spray of hose water. soaped it and rinsed in off. When i started the car, the notifications were: ABS, ESC, Tire pressures. Also the steering wheel had much more resistance (still driveable). The tranny would not let me shift from park until after a few tries.
Intermittently, other warnings popped up after i tried starting the car a few times: Brake service, and one other i cant remember.
I checked the OBD2 codes and this was there: P0600. A Google search says "PCM (Power Train Control Module) Serial Communication Link Malfunction"
So this PCM does appear to be related to those functions. Any ideas before i go and start buying new parts??
Oh and the battery did go flat a few months ago, but ive been charging it and it tested fine today.
Unfortunately the issues are still there.
Does anyone know what i could do to figure out what part i need to replace?
Still much easier than an AH-64 Apache when the mechanics left the cockpit open on the flight line and a snow storm hit that night. *That* took a while to dry out....
FWIW, WD-40 is called that because it is "Water Displacement Formula 40". 40 refers to the number of attempts it took for the researcher to get it right. I used WD-40 multiple times on my old Ford pickup with the inline 6-cylinder. Distributor was in the front and, whenever I drove it in the rain, the ignition would short out, I would pull to the side of the road, raise and clamber under the hood, and spray WD-40 on anything and everything related to the ignition. It then started every time. Of course, I also had lots of dust sticking to the engine. But...my engine ran.
