electrical failure
Old Jan 20, 2004 | 01:37 PM
cherry stout's Avatar
300CD Turbo Coupe
electrical failure
In my 1985 300CD, I have lost all electrical power. I started with the battery(good), alternator(good), and Fuses(good). Now where do I go, too systematically check the whole system for relay falure? TVV@xmission.com
Old Jan 20, 2004 | 08:16 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Check the battery cables and the main feeds to the fuse boxes and relay boxes. Beyond that you will need a schmetic to properly trouble shoot
Old Jan 21, 2004 | 01:54 PM
sph17's Avatar
02 W163, 84 W123, 03 E39, 98 E39
Re: electrical failure
Check/clean your battery contacts of all oxidation, Next, check the main fuse, trace the positive wire from the battery. Make sure your ground wire off the battey hasn't rusted off where it connects to the frame/metal body.
Use a multimeter to check for voltage tracing from the battey towards the fuse fusebox.
let us know what you find.
