2004 Mercedes Benz C Class 220 cdi Aventgarde acts strange when cold
Old May 2, 2015 | 11:45 AM
Kimican's Avatar
2004 mercedes benz e class 220 cdi avantgarde
Hi People, I'm Kimi and this is my very first Merc . I'm very happy with it apart from one strange quirk it has. It always starts first time and runs very smooth, changes gear fine, kickdown works fine. BUT when its cold and for the first 3 - 4 miles it seems as if it cannot make it's mind up which gear to choose ! But after that it's fine and GREAT to drive, I'm retired now through ill health but before that I ran / worked in a garage for 40+ years and I've never come accross anything like this before. Any ideas please to solve this will be very welcome. Thanks, Kimi.
Old May 5, 2015 | 12:42 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
I would suggest checking the gearbox oil level first, They are more sensitive to low gearbox oil when cold. If the oil level is ok then I would be looking to check engine fault codes for anything engine running related(gearbox wouldn't throw any codes for this problem) and then is nothing found I would reset the learning/adaptations in the gearbox (most likely will need your mechanic for this one) and see how it drives after a week of relearning.
Old May 5, 2015 | 08:56 PM
Kimican's Avatar
Thankyou for that BUT there isn't a dipstick for the autobox oil level and whilst I'm on the subject of 'dipsticks' there isn't one for the engine oil either. This is my first Merc but NOT the only automatic I've ever owned. It has what looks like an engine oil dipstick but in fact it's just a red plastic plug that looks like the top of a dipstick ! VERY STRANGE. Where the autobox dipstick should be is a red plastic box and I was told that if I disturb it I have to buy a new plastic pin for it ????? I've never worked on a Merc's mechanics, ( I have rebuilt many Fords, Vauxhalls, Volvos etc but I have resprayed a few of them). All advice and help will be gratefully recieved. Kimi.
Old May 5, 2015 | 10:45 PM
Ausmbtech's Avatar
Order a dipstick for the gearbox from ebay, search for "722.6 dipstick". They are universal and work for all 5spd gearboxes 1996-end of production. Use the dipstick tube with the lock tap on the cap. Break the lock tab off and remove the cap, check the oil level after at least 15-20mons of driving on a level surface with the engine running. You don't have to replace the lock tab, in a workshop environment we normally would though.
Old May 6, 2015 | 06:14 AM
Kimican's Avatar
Thankyou for making that clear, can I get a dipstick for the engine oil too, I'm an old fashioned style mechanic and like to check all the levels on a weekly basis, Kimi
Ps. looking at all the Mercs you have you must certainly like them, I haven't had mine very long (about 5 weeks) I'm certainly 100% sold on Mercs for their style performance and level of equiptment ! ! So it's goodbye to all the other now.....
Old May 6, 2015 | 09:03 AM
biker349's Avatar
cl600
you can order a dipstick for the oil on ebay as well. i think about $28.
Old May 6, 2015 | 02:07 PM
Kimican's Avatar
Thank you very much for sharing you expertise sir, you are a STAR !
Kimi.
Old May 6, 2015 | 11:24 PM
Ausmbtech's Avatar
The engine dipstick only has measurements in mm as it's also a universal dipstick. if you send the first 6 digits of your engine number I'll let you know the mm range you need.
Old May 8, 2015 | 11:58 AM
Kimican's Avatar
FeedbackPositive(15)
Description
Automatic Transmission Fluid Level Dipstick Oil Measure 920mm for Mercedes Benz
Dipstick is designed for most Mercedes models produced in the years 1996-2012 (With the exception of an automatic 722.9xx 7G Tronic) and the brands of Chrysler, Jeep, Dodge, Jaguar, Maybach, Ssangyong equipped with type 722.6xx 722.7xx 722.8xx (W5A180, W5A330, W5A380, WA580, W5A580, W5A900, W5J400, DGJ, DGU, NAG1) Mercedes automatic gearbox.
High quality replacement Mercedes-Benz Part number:
1405891521 And 168589012100
Manufacturer Part Number: 917-321 120-0721 Mercedes Benz 917321
Interchange Part Number: 140-589-15-21 140-589-15-21-00
MERCEDES part numbers: 140-589-15-21, 140-589-15-21-00, 1405891521, 140589152100
Total Length: 92cm/36.2″
Mercedes W210 W211 E class
E180, E200, E200CDI, E200K, E220, E220CDI, E230, E240, E260, E250, E250TD, E270CDI, E280, E280T,
E280 4 MATIC, E290TD, E300, E300TD, E320, E320CDI, E320 4 MATIC, E350, E400, E420,
E430 4 MATIC, E43AMG, E500, E540, E550, E55, E55AMG
Mercedes W202 W203 W204 C class
C160, C180, C200, C200K, C220, C220CDI, C230, C230K, C240 C250TD, C260, C270CDI, C280, C320,
C350, C430, C540 C36, C36AMG C43, C43AMG, C55, C55AMG
Hi Everyone, I found this on Ebay, can you clever people tell me if this is the Dipstick I need for my Merc, I think it is but your knowledge of Merc's MUCH greater than mine. Thankyou in advance, Kimi
Last edited by Kimican; May 12, 2015 at 10:22 AM. Reason: I've ordered a dipstick as you advised
Old May 12, 2015 | 10:25 AM
Kimican's Avatar
Hi all, the first six digits of my engine number are :- 646963 Thankyou
Old May 17, 2015 | 09:38 PM
Ausmbtech's Avatar
The oil level on the genuine dipstick (engine) should be between 139-163mm for engine 646.963
Old May 18, 2015 | 05:44 AM
Kimican's Avatar
Thank you for the ENGINE oil dipstick size, do you have the same for the AUTOBOX please. Kimi.
Old May 20, 2015 | 08:53 PM
Ausmbtech's Avatar
The transmission dipstick has the measurement on it, it looks like any normal dipstick at the measurement end
