Yellowish cream on oil filler cap
Is this normal in winter time? The temparature has been around 20F-30F here lately.
I am also going to keep a more watchfull eye on it to make sure it is not a headgasket leak.
What would the oil be like if there is any water/coolant in it?
When I dumped the oil at the recycling place it looked normal. Just like regular 5000 miles used oil.
IMO, it sounds like it is condensation buildup.
Maybe the weather is just too damn cold here.
I noticed the temparature gauge only reach 80 max on my dash. On short trips it does not even get to that level. In spring and summer it usually goes a little bit above 80.
Coolant level seems to be steady.
If only God could turn up the thermostat a little bit, it would be awesome.
It's gonna be snowing and freezing rain in the next 2 days here.
Wanna trade place? I'd love to trade to Bay area.
Not bad at all.
However, if significant amounts of coolant vanishes w/o dripping to the floor and the used oil looks milky, the posters who suggested a shot head gasket, are right.
The goop on the filler cap is simply normal moisture in the crankcase from blowby.There's unburned fuel as well,so the odor may smell a bit like gas.This is normal for a car that sees only short trips and never gets fully warmed up.What is "warmed up"?..it takes at least 15-20 minutes of steady driving/not creeping in city traffic....at least twice the time it takes for the coolant temp to get warmed up into normal operating range.The definition of "fully warmed up" is a stable oil temp.
Back to the oil foam you're seeing-with short trips it'll never go away.Your current cold weather doesn't help either.
Years ago I was driving a VW beetle to work-3.5 miles each way.
The oil-filler cap's underside was nasty/ugly/foamy.If a small air-cooled engine can do that...
This is also an indication of why short trip-cycles are hard on engines.
