SLS AMG Transmission Oil / Fluid ???
Old Jun 11, 2015 | 07:19 PM
marcelmug's Avatar
bmw x6, sls amg, cooper works
Hi,
I need to refill my SLS AMG transmission with transmission oil / fluid after working on the car and removing the coolers.
The local MB dealer does not have it in stock and can order it........but ONLY in 20 Liters (about 5 Gallons) for 776 USD !!!!
Now I want to have my car finally finished after 9 months and if needed I have to buy this 20 liters BUT maybe someone can help me out and explain what is so special to this SLS AMG Transmission oil / fluid and if there is another solution / oil that I could use.
I want to it as soon as possible...
Help....
Old Jun 11, 2015 | 09:39 PM
marcelmug's Avatar
Found this one online:
Mercedes Part # 001 989 68 03 13
Specification Sheet 236.14 or otherwise known as ATF134
Would this be the one I need?
Old Jun 14, 2015 | 09:48 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
I wouldn't run with that just yet. I'm not an SLS expert, but verify the following:
Model is C197 / R197 ?
Engine is M159 ?
7G DCT ? Model 724 ?
The 236.14 specs are for 5 speed and 7 speed Auto trans, not DCT.
Old Jun 14, 2015 | 10:06 PM
kjb55's Avatar
Try these two links, both SLS specific. One is the ATF hydraulic system (don't think it's what you need) and the other is for the gear set...
http://bevo.mercedes-benz.com/bevoli...nt_action=show
Old Jun 14, 2015 | 11:34 PM
marcelmug's Avatar
Thanks kjb55. Did some checking and looks I need indeed: 001-989-86-03-09 atf (mb236.25)
Found some nearby on Ebay for less then half price of the mb dealer.
