SRS issue 2005 s55
Thanks!
Thanks!
Here's one item I know will light up that error: if you disconnect the battery for long periods of time, the SRS lights up after you reconnect and turn on the car. Stays lit until you have pressed the brake pedal and then turned the steering wheel both ways lock-to-lock to calibrate the steering angle sensor.
Use caution if you make it past these and start checking the actual airbags. Not sure how to test them. Maybe need SDS.
I would reset the code and the take to dealer SRS failure would disperse using and iCarsoft device, but the SRS light would stay on. After turning the car off and back on, the original error message of SRS take to dealer would appear.
I took out my STAR DAS laptop and ran diagnostics. It came up with the vehicle vin, but not the restraint control unit vin- which came up blank. Before pulling the lower dash apart to get the control unit 17 digit number, I just typed in the vehicle vin for the restraint control unit. Five seconds later it said all was well and to clear the error code. I did that and all appears well.
If you are in central PA, come by I will do the VIN entry into STAR for you.
