E55 Question for mbtech208 pls...
Out Of Control!
Hey mbtech
Here's the issue. When i'm driving around 50-70mph and i to press the gas a little bit harder to do a gear change the rpm climbs but the car is not shifting instantly???
Then after 3-4 seconds it starts to kick in. Is this a common problem, problem at all or should i bring it in to the dealer?
Pls advise.
thanks!
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Pls advise.
thanks!
Administrator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
2020 Audi R8 V10, 2016 AMG GTS, 2018 E63S Edition 1, 2018 Porsche GTS Cab, 2012 C63 BS
Re: E55 Question for mbtech208 pls...
Originally posted by JamE55
Hey mbtech
Pls advise.
thanks!
Hey mbtech
Pls advise.
thanks!
1 Post
1997 Toyota Tacoma 4x4
That sounds normal. Benz transmissions aren't instantaneous, you really have to drop your foot down sometimes if you want a downshift. As long as its not slipping or banging into gear, I wouldn't worry.
Out Of Control!
I only have about 1800 miles on this and only have floored it once so i may have to break it in a little bit more. Now i don't feel so bad.
thanks again Dave!
Out Of Control!
Originally posted by darkLCD
JamE55,
Try touchshifting down 2 gears successively & quickly...and floor it.
JamE55,
I don't really like to use the touchshifting feature as i always set the gear into drive mode.
1 Post
99' SLK 230 & 01' CLK 430
JamE55.....i get that problem all the time when i floored my Clk 430 but.............
now i learned and get used to shift manually side way instead of the more commom sense up and down. There's no lag if you down shift manually.
