difference between "Tune-Up" and "Service"
Old Feb 10, 2004 | 12:02 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
hey all,
ok, what is the differences between a "tune-up" and "major service"? tune-up and service (major) --> spark plugs, oil and filter change, air filter, cabin filter, check hoses, fuel filter, etc, right?
Old Feb 10, 2004 | 03:00 PM
Kestas's Avatar
95 E320 Cabriolet, 108K
From what little reading I've done, it may include things like:
- Change coolant
- Flush brake fluid
- Change differential fluid
- Change transmission fluid and filter
- Regrease and set preload on front wheel bearings
- Clean and grease parking brake mechanism
- Lube hinges (door, hood, trunk, latch)
- Change hydraulic fluid in self leveling suspension
- Check fluid level in cabriolet mechanism
- Clear body drain holes
- Lube sunroof slides
Old Feb 17, 2004 | 05:12 AM
230TErry's Avatar
93 320CE, 72 280SE 3.5, 55 220A, 05 E280CDI, 88 Mini Mayfair, 90 Peugeot 205GTI, 04 Mini Cooper
A tune up involves setting timing, fuel air mixture etc. and strictly speaking does not involve replacing any parts.
On more recent cars this involves plugging in to a computer and checking that all settings for the above are correct.
