Question about fuel level sending unit
Old Feb 17, 2004 | 02:30 PM
QB320's Avatar
Hello. I too now have the fuel sending unit problem (98 CLK320). Unfortunately, car is out of warranty. I'm not sure if the service manager will fix it with goodwill since it's a known problem.
Question: Is the unit simply for convenience (telling me when the gas is low) or will it cause any safety, performance, etc problems?
Thanks in advace.
J
Old Feb 17, 2004 | 04:19 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
I believe the fuel sending unit is just to report back to the driver VIA the cluster how much fuel is left inside the tank, but there may be other uses for it.
I know that when our ML fuel gauge was off (when filled, it would only register 3/4's), they replaced the fuel sender unit and all was well again.
Old Feb 17, 2004 | 07:05 PM
redcoupe's Avatar
11 ML350
Your problem is just with the level sensor, so you'll be ok.
Brian
Old Feb 17, 2004 | 07:51 PM
sph17's Avatar
02 W163, 84 W123, 03 E39, 98 E39
Re: Question about fuel level sending unit
Thanks in advace.
J
There are two sending units in a W202 (C 280). The one closest to the fuel filler measures the pressure in the tank, and if the gas cap is left off, will put light the CEL. After replacing the cap, I am told the CEL goes out.
This is the only other use I know for these units.
