2007 W211 E350 P0715 code?
Old Jul 14, 2016 | 09:27 PM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
Code shows as Input Speed Sensor.
Transmission went into limp mode and check engine came on.
Assuming it is the speed sensor, it looks like I need a new conductor plate.
Is that a good guess, or are there other common issue that trip the same code?
Old Jul 15, 2016 | 10:24 AM
N_Jay's Avatar
Have an appointment with my local indy shop.
He said there are a few checks, but given the year and a few he has had in recently for the same issue, he does not doubt the diagnosis.
Heck, that extra $800 in my checking account would have just been wasted on fine wine and dining.
P.S. Fluid was done about a year ago, all was good then, and he put the adapter on the connector so it should not be a fluid soaked wiring harness.
Old Jul 16, 2016 | 01:23 PM
mtnman82's Avatar
'16 E350, gone: '03 c230k
N-Jay, please follow up and let us know how it went. Do you have the 722.6 (5-speed) or 722.9 (7-speed) tranny?
I have an '03 c230 throwing the same P0715 and am tempted to pull the trigger on a new conductor plate and have it changed out.
Old Jul 16, 2016 | 05:38 PM
N_Jay's Avatar
Scheduled for Wednesday.
Yes, 5 speed (2008 4Matic)
Old Jul 17, 2016 | 03:46 PM
mtnman82's Avatar
Thanks N_Jay! Will be looking forward to your results.
Old Jul 26, 2016 | 03:47 PM
mtnman82's Avatar
Any update on this N_Jay?
Old Jul 26, 2016 | 04:07 PM
N_Jay's Avatar
Sorry for the late answer.
Yep, new conductor plate (which has the speed sensor in it) and all seems well (Except my wallet)
Old Jul 27, 2016 | 01:51 PM
mtnman82's Avatar
Thanks for the reply N_Jay. I ordered the parts to do this myself, but since then the tranny went into limp mode (stuck in 2nd gear) so I think I'm going to take it to a shop. I'm worried about needing to clear the tranny computer to get it out of limp mode and my hand scanner can't do that. Kind of a bummer this happened now because I just replaced the leaky connector adapter, filter, and fluid around Christmas. Since it's being taken apart, going to replace it all again.
Old Jul 27, 2016 | 02:16 PM
N_Jay's Avatar
Mine came out of limp with a restart.
Old Jul 30, 2016 | 02:14 AM
mtnman82's Avatar
Hmmm, thanks for that info N_Jay. Did you notice any other safeguards kicking in?
I got the parts but chickened out on doing this one myself. I was afraid I would still have to clear some transmission codes after I replaced the conductor plate with it being locked in 2nd gear. It also would start to limit the engine rpm's to 3000rpm after I drove for a few miles (it was 8 miles to the transmission place). I talked to a transmission shop with excellent reputation who turned out to be familiar with the 722.6, leaky connector adapters and replacing conductor plates. He told me if I wanted to replace it myself I should do it and that the codes and all the weird driving behavior would clear itself with the new conductor plate. I wound up just having him do it - this past Wednesday I dropped the car off at lunchtime and he called me before quitting time that it was done. I had just changed the oil/filter/connector adapter at Christmas, but nevertheless bought the kit with the conductor plate and new fluid/filter/connector adapter/pan gasket/etc. so all that was replaced. Drives great. Looks like all they did was have the battery disconnected while they did the job and no codes.
