Tech help with Truck Lid adjustment on W211
Old Mar 15, 2004 | 06:33 PM
Randy B's Avatar
**SOLD***2003 E500
Thumbs up Tech help with Truck Lid adjustment on W211
To any and all Techs out there. I have a 2003 E500, and the trunk lid opens fine, however it does not stay in the up position very well. And if the car is tilited toward the back, forget about it. Is it possible to adjust the tension to put a little more pressure on the up mode???? I do not have the auto open close feature. This is a 2003 E500. Thanks in advance!
Old Mar 15, 2004 | 06:50 PM
SUNILP's Avatar
2015 E250D
Yes you can!! Many people have to do this if they install a spoiler on the trunk. What you will have to do is remove the inner lining in the trunk on both left and right side. You don't have to remove all the clips but remove enough clips so you can see the large spring behind the lining. Each spring has 3 spots for adjustment. Adjust as necessary. I had to do this on my c class after I got the Lorinser spoiler put on.
Old Mar 15, 2004 | 11:44 PM
SUNILP's Avatar
2015 E250D
you can check my website and one of the pictures has the spring that you need to adjust. It's the pic with the nokia phone kit on it. MY WEBSITE
Old Mar 16, 2004 | 05:50 PM
Randy B's Avatar
**SOLD***2003 E500
Smile Thank You!
Thanks Sunman, I got it adjusted today. Real easy. Left one was on hole 2, and the right one was on hole one. Now both are on Hole 3.
Old Mar 17, 2004 | 08:48 AM
SUNILP's Avatar
2015 E250D
Make sure it's not too tight! This can cause the trunk lid to slam open too fast and loosen your hindges.
