water in headlight
Old Mar 16, 2004 | 05:58 PM
pointman's Avatar
a car that can't do the throttle reset.
water in headlight
my headlight assemblies get a little fogged up when it rains. i was curious if this is something that i have to worry about. will it cause any damage? it goes go away on its own.
Old Mar 16, 2004 | 06:57 PM
Randy B's Avatar
**SOLD***2003 E500
Sounds like the gasket on the back of the unit is not sealed. Have you replaced a bulb lately????? Also just to make sure what model and year??
Old Mar 16, 2004 | 07:51 PM
pointman's Avatar
actually the situation is that i put the 02 headlight assemblies on my 00 ml320. at the same time i made the halogens hid's with a retrofit kit. so, i attempted to have them resealed but its a real pain in the a**. just curious if i tis something i have to have repaired or can i just leave it the way it is? thanks for replying.
Old Mar 16, 2004 | 07:59 PM
redcoupe's Avatar
11 ML350
If you dont waht water in your headlights then I would get them fixed.
Old Mar 16, 2004 | 08:06 PM
Randy B's Avatar
**SOLD***2003 E500
Definitley need to get that fixed. If water starts getting on those lines with the high voltage you will not have a good day.
Old Mar 16, 2004 | 08:26 PM
pointman's Avatar
how bad do you think it could get?
Old Mar 17, 2004 | 06:58 AM
Randy B's Avatar
**SOLD***2003 E500
Worst case, you blow the ballast or the bulb, and cause a short. It will make one hell of a pop when it happens.
Old Mar 17, 2004 | 02:11 PM
pointman's Avatar
thanks for the help. i guess ill take it for the third time to try and get fixed, thanks
Old Mar 29, 2004 | 06:54 PM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
There is a technical bulletin for ML headlights fogging. They say it is normal, and the condensation will evaporate after about a half-hour of driving with the headlights on.
Old Mar 30, 2004 | 12:42 AM
pointman's Avatar
really, thanks for letting me know...makes me feel a little better.
you think thats believable?
Old Mar 30, 2004 | 12:43 AM
mbtech208's Avatar
Only one way to find out, go for a drive.
Old Mar 30, 2004 | 02:24 AM
pointman's Avatar
the condensation does evaporate after 30 min, even without headlights on... just got worried when told could cause a short.
whoops, should have read your name before doubting you, thanks for the help!
