Does the Air Conditioning Compressor Disc always turn on a 2007 ML350? No cold air.
Old Mar 16, 2017 | 09:18 PM
Frisbeeman1's Avatar
2007 ML350
I'm not getting cold air with the AC. The disc associated with the AC pully on the poly belt, the lower right one looking from the front of the engine, is always turning with the engine running, whether the AC is turned on or not. I am used to vehicles where that only turns when the AC is on. Does anyone know if it always turns on an 07 ML350?
I tried to add coolant to the lower pressure side filling attachment. But the Mercedes receptacle is so deep I am not sure the filling attachment I have is reaching down far enough to open up the valve to allow coolant into the car's AC system. Does anyone know if a special attachment is necessary for filling a Mercedes AC system?
The coolant level must be really low because when I use a small screwdriver to depress the low pressure valve inlet only a tiny bit comes out, like a tire with 3 psi in it. With the engine running, when I turn the AC on with my friend's head under the hood right over the engine compartment there is no audible change in noise, no clicks, no nothing.
Anyone know what I can do to get my AC going?
Old Mar 17, 2017 | 05:57 PM
TommiM's Avatar
2015 C300, 2014 GLK 250 Bluetec
no special attachment needed that I ever had to use. Not sure what could be the problem without more info though. It may not necessarily be low refregerant. It blows air, just not cold, correct? does the low side line get cold to the touch? If you are able to get gauges on it and pull some codes we might be able to see whats going on?
Old Mar 17, 2017 | 10:27 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Start learning about "swash plate air conditioning compressors".
Here's one for introductory info:
https://axleaddict.com/auto-repair/V...nt-Compressors
Old Jun 18, 2017 | 01:45 PM
smiledr996s's Avatar
2008 gl320cdi
Mine has been doing same for over a year. Although it is happening more consistently
mechanic recently looked at it and told me it is a valve sticking. I think external. But said whole compressor would need to be changed. I am waiting to see. I would like to recharge and may try first to see if fixes.
Old Jun 18, 2017 | 02:16 PM
benzslo's Avatar
C43 5.4, ML320CDI, Fords
It does not have an on and off clutch. It is a variable compressor and is controlled within the compressor, you won't hear a click or any noises.
I'd take it to your dealer for a proper diagnosis.
