mbtech208
Old Nov 26, 2001 | 10:27 PM
linh's Avatar
99' SLK 230 & 01' CLK 430
mbtech208
mbtech208....when you change the coolant on the slk and clk, do you need to "bleed" the coolant system? Or it is a self bleeding system? And if it need to bleed, where is the bleed screw? Thank you very much.
Old Nov 27, 2001 | 12:35 AM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
There is no need to bleed it. The cooling system was designed to prevent air pockets from forming. Just remove the cap, drain the radiator, and refill the system.
