60,000 mile b service
I have a 2000 E55 AMG (W210). According to the FSS, its time for the 60,000 mile B service. My question is:
(1) just exactly what is done?
(2) is the transmission fluid changed?
(3) is the ignition coil changed?
I ask b/c I know I am going to get a big bill from the dealer so I just wanted to know what exactly they are going to do? Thanks ahead of time for any reason!!!
2003 CL55 AMG
Flexible Service System - B-Service
- Change your vehicle's engine oil and filter
- Replace the dust filter in all SLK, CLK, C-Class and E-Class models,
and in S-Class and SL-Class models without the active charcoal filter
- Replace windshield wiper inserts
- Inspect and rotate tires
- Lubricate and inspect throttle linkage
- Ensure the parking brake, steering play, headlamps and exterior lamps,
warning and indicator lamps, horn, windshield/headlamp wiper and washer
systems, seat belts, and backrest lock (S-Class only) are functioning correctly
- Inspect tires and check tire pressure (including spare)
- Inspect brake pad thickness and disc condition
- Inspect front axle ball joints and Poly-V-belt
- Check and correct all fluid levels
- Reset your vehicle's FSS counter
2003 CL55 AMG
Go to MBUSA and use the find dealer option. Once you are on your dealers web page, you can find this info in the Service area of the page. It is pretty much a cookie cutter MBUSA design page that MBUSA gives them.
1997 Toyota Tacoma 4x4
If the car is in for an A or B service and it is near the 2-year anniversary of the in-service date, it gets a brake fluid flush under warranty. Same with the coolant at the 3-year mark. Unfortunately, since you are at the 60K mark, your car is out of warranty. You will also not get the dust filters or wiper insert included with the service, you will have to ask for those. I'd recommend changing the fuel filter too, it needs it every 60K miles.
