Transmission Fluid and stuff
Just wondering how often should I change the ATF
Also, for a E320, on average how long do the tranny last?
There seems to be an assumption that MB engines pretty much could last forever (or at least 500K) without major overhaul .. myth or fact?
Either case, even if MB engines do last a lifetime, and the body stucture/frame pretty much last a long time too, but if everything else falls apart after 5 years... it means very little.
I Have seen Several fail Just out of MB warranty ..Then The Customer pays the bill..The Fluid was cooked on them
Its Best to change the Fluid and filter every 60k ..dont forget to drain the torque converter
most MB transmissions will last over 150k if taken care of
They seem to think that the extended is more prone to gum things up.Would this work on my e320 with no bad side effects.Or should I just stick with the extended.
Guess I should change it to the orange/extended life coolant. Anything special I should know about changing it? Is there an air purge valve in the coolant path somewhere on the 3.2 liter V6? Thanks for the heads up Dave
It just passed 62,000 miles...but the shifting is still very smooth (not during cold starts but when warmed up, very smooth).
Thanks!
