'02 CLK320 Passeger Window Issues
I've since picked up the car from the shop and they've left the panel off so I can still work to fix it. I picked up my old damaged door to be able to have the components from it in case it is needed. I have switched out my old window controller into this new door to see if that solved it but it hasn't. I've also lubricated the channels, and trim to make sure nothing is causing the window to think it needs to come down for safety concerns. I've also removed the inside edge trim.
The window will go down fine and stop midway if needed. However, when going up, if you release the button, it immediately comes down 2". Also, when it goes all the way up, it immediately comes down 1". I'm stumped and any help would be appreciated. Thanks in advance!
Below is a video.
It must be 100% free or you will have issues, then use a diagnostic tool to desyncronise the end stops, then teach it back in using the window button
