P02CD - Clyinder 1 Fuel Injection max Learning
Old Jan 26, 2018 | 11:23 PM
CdnNick's Avatar
2014 ML350 bluetec
Vehicle is 2014 ML 350 Bluetec
recently the light came on.. zero issue.. then at idle about a week later now it’s having a bit of a rough idle, but only in park.. in gear it’s fine.
doesnt madly fluctuate rpm.. just rougher then usual.
110,000kms
due for B service in 10,000
Also has stored clyinder 1 and stored cylinder 4
thats front of engine.
not sure why 1 is permeant and 4 is only stored.
I can check some simple stuff tomorrow, any suggestions? Ive hard the diesel isn’t great this winter, but just water in it.. The filter / separator should be able to keep up and there should be a code if it sensed that.
Old Apr 9, 2020 | 11:09 AM
Chamelleon's Avatar
ML500, ML350 BT, GLE 400
Hi there.
I am having the same issues: rogue idle only in P gear, CEL and after scanning it popped out the code P02CD.
Any advice?
Thank you
Old Apr 9, 2020 | 11:24 AM
CdnNick's Avatar
2014 ML350 bluetec
Yea I figured it out..
crappy fuel and or lack of cetane..
I use a cetane additive and it hasn’t come back.
Old Nov 24, 2020 | 09:01 PM
gsehmbi89's Avatar
2014 Mercedes ML350 Bluetec
I am having the same problem as well. I also ended up topping up my DEF fluid and it took the entire jug of it.
Going to try a cetane additive and hope that it clears it.
Old Mar 30, 2021 | 02:06 AM
Ryan Okion's Avatar
2014 GL350
What brand of cetane additive you used? Thanks
Old Mar 30, 2021 | 02:09 AM
Ryan Okion's Avatar
2014 GL350
​​​​​​After you fill up the DEF, is the code went off?
