1988 260E M103 Starts Then Stalls
I replaced the spark plugs, spark plug wires, high tension lead, distributor cap and rotor. I replaced all the fuses and cleaned all the oxidation off of the fuse terminals. I cleaned all the ground connections. I learned that a battery can appear to be ok, and cranks the motor, but can fail to provide sufficient cranking amps to properly power . Using the Solar tester recommended by Kent, I tested my battery and the battery failed, so I replaced it. I also discovered my idle control valve was not functioning, so I replaced it.
So, after all this work the car starts right up, and runs smoothly for exactly 12 seconds, then quits. When it quits, it just cuts out like the key was turned off. I have to wait about 10 or 15 minutes before it will start again. Each time it starts, it runs for exactly 12 seconds, then quits. There must be something that occurs with the fuel injection system, or the electronics about 12 seconds after starting, that causes it to stall.
Does anybody have any ideas? I am wondering if the problem is my ECU or perhaps the ignition coil. I am running out of ideas....
Thanks,
Reg
Last edited by 55chevreg; Mar 25, 2018 at 08:24 PM. Reason: Need to correct some errors
