2017 C coupe making high pitch sound after parked for 30 minutes
Old Apr 17, 2018 | 08:30 PM
StephenW2016's Avatar
S550 E350 C300c
Our 2017 C300 coupe sometimes will make a siren sound after parked in the garage for 30~40 minutes, it'll stop after a minutes or so. There're no other devises in the garage or anything nearby would make such sound.
Happened (or got caught) 4 times already, went to the dealer, hooked up to computer and no fault code.
Finally caught it on video twice in the garage, I don't know if you can hear it clearly but this is what it sounded like:
Anyone ever heard of such a sound? TIA.
File Type: mov
File Type: mov
Old Apr 17, 2018 | 08:55 PM
ItalianJoe1's Avatar
2003 CL 600
Does your car have the LED headlights?
Old Apr 18, 2018 | 12:45 AM
S550 E350 C300c
Thank you for your reply.
I'm not sure what kind of headlight it has, my wife lost the original window sticker.
Do you think the LED headlight has something to do with it?
Old Apr 18, 2018 | 02:20 AM
S550 E350 C300c
I'm not sure, my wife lost the window sticker.
Do you think it has something to do with the sound?
Thank you.
Old Apr 18, 2018 | 03:10 PM
2003 CL 600
Yes, the LED lights have fans in them that can run up to an hour after to control temperatures. There have been instances of it being reported like this, so it may very well be normal.
Old Apr 18, 2018 | 08:38 PM
S550 E350 C300c
Thank you so much for your help, I just found out this coupe has LED headlight.
I'll go check with my service adviser if he knew anything about it.
Best regards.
Old Apr 21, 2018 | 12:32 AM
S550 E350 C300c
Will the fan start to work 30 minutes after engine off? Because all 4 times we caught it were about 30~40 minutes after car parked. And all happened in daytime. Thank you very much.
Old Apr 21, 2018 | 12:33 AM
S550 E350 C300c
And this is what it sounded:
File Type: mov
Old Apr 21, 2018 | 08:02 PM
2003 CL 600
It may be another pump running, it's hard to say. There are several. Even auxiliary coolant pumps to keep the turbos at a controlled temperature as the car cools down. Anything can run at weird times after shutdown if the conditions are right.
