Location of A/C temp sensor?
Old May 21, 2004 | 11:30 AM
Krycheck's Avatar
'99 C280
Question Location of A/C temp sensor?
I'm gonna replace the A/C temp sensor. I was told it was on the drivers side under the dash. Can someone tell me excactly where it is before I start tearing it apart?
Old May 21, 2004 | 02:09 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Remove the LEFT under dash panel and the A/C evap temp sensr is located in the Evap case ...it can be reached fron the left under dash ..Buy The sensor first to help you !
Old May 21, 2004 | 03:41 PM
Krycheck's Avatar
'99 C280
Thanks. I do have the sensor. I take it the evap housing is behind the console. Hopefully this is the problem I have with my A/C blowing hotter when I set it colder.
Old May 22, 2004 | 01:37 AM
Krycheck's Avatar
'99 C280
Well that was somewhat tricky to find but I got it replaced. Although what I got didn't look the same as the old one but I put it in. Seems to blow colder but we'll see tomorrow when it's warm.
