Adblue pump failure, heater failure P20E8 code question
Old Apr 27, 2018 | 12:42 PM
jlowe99's Avatar
GLK 250
I have a GLK250 and I have the CEL with code P20E8.
I've seen a number of people with this issue and I'm wondering what happens if you ignore it? The vehicle seems to run fine with the CEL.
The issue seems to be low pressure from the DEF pump. If you ignore it does it just mean the exhaust isn't meeting emission standards (we don't have tests here in Canada) or will it lead to bigger issues?
I will be taking it in for service in a couple of weeks and I was wondering if it could wait until then.
Old Apr 27, 2018 | 05:22 PM
jlowe99's Avatar
GLK 250
When I clear the code it disappears for a day or so and then comes back.
I'm wondering if anyone has a technical understanding of the system and what the implications are. The Adblue system receives signals from the computer based on sensor inputs I assume. Based on those readings it injects a measured amount of Adblue into the exhaust system. They have a sensor that measures pressure and throws a code if the pressure is too low. That is how I think it works in simple terms. Given that the ECL disappears for a period of time when it is cleared it seems to meet the pressure threshold some times but also is below some times. That suggests to me that either the sensor is faulty or the pump is inconsistent rather than an actual pump failure. Anyone out there that understands how the system works that can critique my thinking?
