HHT software
Old Apr 16, 2002 | 09:05 AM
scorchi0's Avatar
W124 230TE, W123 280E
HHT software
Does anyone know if there is updated software available for the MB Hand Held Tester?? or if someone has developed the software for use on a PC. A company has done that with the Audi/VW 1551/1552 tester, and created commercially available PC software that connects to your car via the parallel port..
Is this available for Mercedes and if so, Where???
thanks in advance
Trent
Old Apr 16, 2002 | 02:59 PM
Richard's Avatar
2004 SL55, 2015 A250d, 2016 GLC250d
Do you have a MB HHT ???
Old Apr 17, 2002 | 09:13 PM
scorchi0's Avatar
maybe
Old Apr 21, 2002 | 05:49 PM
patrick's Avatar
The HHT-software exists for use on PC. But I think you 'll need a few more things to have the system working.
Old May 7, 2002 | 02:56 PM
mverboom's Avatar
C270CDI Avantgarde 2001 Sedan AMG rims and skirts
Re: HHT software
thanks in advance
Trent
I don't know what you can do with a Hand Held Tester. What I do know is that with recent MB's you can use the OBD to get information about fault codes etc. I tried it, it works and it's not very expensive.
Hope this helps,
Mark
Old May 8, 2002 | 10:52 AM
scorchi0's Avatar
You can do EVERYTHING with the HHT, like full tests of all electronics in the car, even compression tests!! It measures the load on the starter motor to test the compression while disabling the ignition...very neat
Old May 8, 2002 | 06:35 PM
newMBz's Avatar
2002 C320 c2/c3/c4 & command
Just found out this website and this company offer a software which has all the function as the STAR DIAGNOSTIC SYSTEM. Chech it out.
WWW.CARSOFTINTERNATIONAL.COM
Old May 8, 2002 | 08:00 PM
awiner's Avatar
2003 CL55 AMG
As pointed out in another thread, the above system DOES NOT have all the functionality of the Star Diag System. The Star Diag System is able to program/reprogram various ECU and system setting/values that a ODBCII reader/tester (Some even act as a semi ODBCII programmer) can not do.
