CLA45 Filler door actuator
Old Jul 4, 2018 | 10:09 AM
LGAFF's Avatar
2011 E550 Coupe, 1992 Corvette ZR-1, 1991 368ci ZR-1, 1990 ZR-1, 1987 Callaway TT, 05 SL600, CLA45
Anyone have the process to replace this.....under warranty but dealer is refusing to honor replacement, apparently I need to keep randomly having to manually open the door with the emergency.
$70 part
Old Jul 4, 2018 | 12:41 PM
LGAFF's Avatar
based on videos of other models, look like I need to use a plastic trim pry to pop off top and bottom of the filler lid assembly?
Old Jul 4, 2018 | 04:18 PM
ItalianJoe1's Avatar
2003 CL 600
It no longer opens at all?
if you can get it to open, it's easy to remove. If it's stuck closed, yes you need to pry the door cover off and it will likely break the clips.
If it opens, remove the trunk lining on the left side and you can reach in there and remove the actuator. I'll try to find the WIS instructions. They don't account for a stuck closed lid though.
The recess removal doc covers unclipping the latch actuator, attached the file. Hope that helps.
File Type: pdf
Old Jul 4, 2018 | 04:26 PM
LGAFF's Avatar
It opens sometimes and with the emergency switch ....... it keeps failing off and on and I have to go through he trunk to open it....Mercedes refused to replace as it worked the day I brought it in...after weeks of off and on failures, opening by itself and then not opening.
Old Jul 4, 2018 | 04:31 PM
2003 CL 600
That sucks, ****ty service department. They fail on the CLA from time to time, and occasionally on the 166 trucks. Usually only find out when the car is about to run out of gas so we get it as a tow in with a pissed off customer, always fun. If we have to break the lid to remove it, then have it painted, it always goes over well.
Old Jul 4, 2018 | 05:06 PM
LGAFF's Avatar
This is huge help, looks like what I thought this is just an interference fit with the tabs at the bottom....thanks so much
