Help, Ckimate Control Gone Wacky
Here is what it's doing:
-auto mode: a/c will run cold but only to top vents and HOT air blows on the feet continuously.
-Manual mode: the fan speed works fine HOT air on floor only/continuously and modes will not work.
-defrost works, just can't control the temp.
Any thoughts? I double checked to see if everything was plugged in and it looks fine. I have the standard analog temp comntrols in my coupe.
Please help. I would rather run a test or reset procedure if one exists then have to take it in.
-Thanks, Eric
Can anyone tell me why after I installed a new head unit my climate control worls weird now.
-Thanks, Eric
2) what kind of head unit did you have installed in the car. Is it original, OEM, aftermarket, etc.
3) who did the install. Did any of the connectors to the stereo change, like with an adapter, or cutting wires?
There are wires going to the stereo for the CANBUS. The climate control is also on the CANBUS. This could cause a problem.
-s-
