2011 CL550 Malfunction Arrow / Airmatic Issue / Right side Leaning
Old Jul 21, 2018 | 04:31 PM
ooboo autos's Avatar
Mercedes CL550
So I was driving my 2011 Mercedes CL550 yesterday and all of a sudden the "Malfunction" Arrow Up error message comes on. I turn off the car and go outside to check out the car and it seems as though its leaning to the right (passenger side) slightly. The front passenger bumper seems lower then usual. I turn on the car and the car is able to rise, including the right side, however, it still is not leveled with the left driver / side.
Any ideas what issue this is? I'm pretty sure it's not the compressor because the car rises fine. With more initial research, I thought it was the front passenger strut having a leak. However, wouldn't the airmatic not work at all and it would not be able to rise when I turned the car on? Could it be the airmatic control module causing the car not able to level evenly? Could it be fuse, or would that case the entire airmatic system not to work?
Also, keep in mind, I am in Dallas, Texas, it temperatures have reached to around 105 F or even higher, so not sure if this is a contributing factor.
Old Jul 28, 2018 | 01:02 AM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
You have a leak in that strut, be careful or you'll burn out the compressor.
Fix is replacement strut.
