Pick a SAM any SAM, troubleshooting
I service electronics and now aircraft and am shopping for SDS. until then I am trying to determine core power issues and no OBD2 link even.
Here is what works
Alarm, sounder rf, dash display and key recognition, ABS pump, map lights, headlites, door sensors,gong, command screen, steering adjust
Does not work
Engine crank, windows,horn, lower courtesy, audo sound, trunk lit and release, air pump, partial seat OP, trunk release indicator always lit, mirror ajust
What I checked
All fuses and pre fuses, every static voltage on fuses Only left and right front SAM fuse boxes show missing voltages on fuses, rear SAM fuses are all 12v,
With this INFO can anyone out there determine which SAM I should SMD rework? These cars are poorly built for the level of tech especially open to corrosion fuseboxes etc Yanking on more wires would escalate the anxiety attacks. Is there a voltage chart of FUSEs in standby?
Left frt SAM 13 (0 volt fuses)
Right frt SAM 11 (0 volt fuses)
I respond with THANKS
