Climate Control Randomly Cycling Modes/Losing Power
I have done the following troubleshooting, based on internet searches:
Climate Control Module – This seemed like the most reasonable solution. I purchased a module off eBay, from a wrecked car. I installed it, and It shows the exact same symptoms.
Fan Control Module - I don’t believe it’s the fan module, because it is responding to the signals from the climate controls when it gets them.
Battery – I tested the battery. It said good, but needs charged. I charged the battery and retested to make sure it was good. I am still having the same issue.
ECU – The only code I get is “Communication with the air conditioning has a malfunction”. This goes away when the climate module has power. If it was the ECU, I’m guessing I’d get more codes.
Fuses – I checked the fuse (19), and it was fine. Are there other fuses? I’m guessing if it was a fuse, the issue wouldn’t be sporadic. I did pull the fuse, hoping to just disable the system. When I do this, the engine fan runs all the time. I read that this is a common response when it losses signal.
AC DTC – I have the following DTC under the AC: “The power supply to the LIN bus subscribers has a malfunction. The limit value for current has been exceeded”. I don’t know what this means and haven’t been successful in searching these codes.
Any help would be appreciated. I have an appointment at the dealer, but they couldn’t get me in until later this week.
