Headlight, Turn Signal and Horn Problem
I'm still doing some searching, so bear with me if I ask a repetitive question. 2005 CL65 AMG - I have gone over some of the obvious wiring issues at the headlight, but haven't checked the ignition switch or the grounds yet.
Drivers side low beam works fine when car is off, so does the passenger front turn signal (mirror signal works at all times) - but when you start the car or turn the key to the ON position, both no longer function.
Also, sometimes when turning the car off the horn with do a quick beep with the turn of the key, sometimes multiple.The horn on the steering wheel does not work, I have yet to disassemble it yet to verify it's plugged in.
Any thoughts? Is there a specific relay or module I should check out? At some point I'm removing the bumper, this car seems to have been apart and back together a few times so I'm sure I'll find all kinda of fun stuff. Thanks in advance!
