P0025, left exhaust cam problem, camshaft adjuster or adjuster solenoid failure?
Hello! I'm working on figuring out a problem with my 2007 Mercedes e350 4matic with the 272 engine. The car makes grinding/clicking noise a few seconds after start up, has a slight misfire at idle, and a more noticeable one on start up. The noise and misfire are far worse when outside temperatures are low. The noise and severe misfire at start up generally only manifest on cold start/first start of the day. I also have misfire codes for cylinders 4-5-6, which correspond with the left exhaust camshaft adjustment position code. What I'm now trying to determine is this: does this sound like it's a failure of the magnetic camshaft actuator, or the actual mechanical camshaft adjuster, which I believe is attached to the timing chain and much more involved to replace? Any tips on determining the culprit, other than removing and testing the magnetic camshaft actuator? Thanks!
