Help, Head Unit Reads "No CD Changer"!
CLK430
When I press CD on the head unit of my w208, it reads "No CD Changer." I checked the cd changer and it powers up. It seems that head unit is not communicating with the changer. Recently, some nucklehead that was detailing my car unplugged the battery and I think this somehow may have caused it
FYI, my car also has the intergrated phone feature which I have not used yet.
Is there some code that I have to program the head unit with so that it can work with the changer again? This happened last night and I still have the problem today.
Thanks in advance for the help.
![hammer](https://mbworld.org/forums/images/smilies/bonk.gif)
I had this problem only one time. The only thing I did was power off the head unit, remove and reload my cartridge into the player and power back on the head unit. It was maybe just a fluke but it worked for me. I typically don't even turn off the head unit when I am changing CD's.
Integrated phone you say? Sounds like you need a new PSE. If you dont use the phone, just bypass the pse. May be easier to let the dealer do this, certainly cheaper to bypass than to replace if you are not going to use the phone. Unless Its a V-60 you are probably better off doing away with it anyway.
Do you have the c/d icon on your radio screen? If you do it is recognizing it. If you don't it is probably the fiber optic line. The D2B line goes from the radio to the amp to the C/D then to some Ecalls and to some telephones . It wakes all these units up when you turn the radio on. An easy way to check the D2B is to get the OLD LADY or as some say the bose of the house out there with you. Then at your C/D player unplug the D2B line. The D2B line is two orange lines that run into a black connection. Look at the end of it and have your better half turn ON the radio. You should see three or four flashes. If you see them it is O.K. if you don't then get out the check book. Hope this helps, Autogunner.
