CLK55/M113 Dual Spark - please explain
I have a 2003 CLK55 AMG with the 16 spark plug motor.
A couple of questions:
- What is the reason for the 16 plug design?
- How do I know if 1 of the plugs or 1 of the plug wires is not working?
I have a tool that can read Mercedes codes, and it is not showing any issues at the moment.
https://en.wikipedia.org/wiki/Dual_ignition
Using MB Xentry Das it does tell you when 1 or 2 are not working yes
cheap tools should read those codes too
and don't complain I have 24 spark plugs I replace every year and a half
breeze247 (06-21-2020)
Thank you!
Does anybody know who the OEM manufacturer for ignition leads is?
breeze247 (06-27-2020)
So, the ignition leads have arrived.
16 leads, as expected, along with 8 steel rings. The rings are a bit like key rings.
Does anybody know what the rings are for and why I might only have 8?
No instructions in the box, sadly.
Edit: the rings were actually from the tips of the leads. They are used to keep the end of the lead under compression. 8 were on the leads and 8 were in the box. Simple!
biker349 (06-29-2020)
