Diesel Injectors
Diesel Injectors
The 1990 to 1993 MB 300D (124 chassis) 2.5 Turbo Diesels where all the 602, 5 cylinder engine. Question is are there any other Injectors that will fit this engine? Like another MB Diesel engine that uses the same injector?
Is there an interchangability chart out there some where?????
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Most likely not. The injectors are callibrated for fuel flow and spray pattern to use in a specific engine. Why do you ask?? Just have the correct injectors installed or you can create more problems than you already have.
Diesel Injectors
I have seen other Injectors from other MB Diesel cars for sale and wondered if they would fit. Also changing nozzles could / can add more power to an engine, IF done correctly, so..... Just thinking..... And that alone could get a guy into trouble..
Thanks for the info.
