S212 E350 Airmatic starting to fail
It has happened me twice recently that after too happily passing a speed bump, the Instrument cluster showed the airmatic malfunction message.
First time i didnt stopped and after to more messages turning from orange to red, and car sagged on both front wheels. After a stop and start, suspension went up and never happened again for about one month until yesterday, when after also too quickly passing a speed bump, cluster showed the Airmatic malfunction again.
This time i stopped the car, restarted and the error dissappeared. Car drives fine after that, no sagging, no compressor running a lot of time.
I connected with xentry and found this error:
I understand that at the moment the error occurred it was sending air to FrontRight strut, but i dont see how that relates to the strong compression caused on the shock absorber by the speed bump.
Dont the struts have a local pressure valve? maybe it was opened at that same time and the air returned to the valve block causing the error?
What do you think about it? may i start focusing on the front struts, or on the valve block?
Al xentry pressure tests succeded.
Thank you in advance guys!
So wanted to know if someone with more knowledge can associate this with some failing part. Otherwise i'll start by changing the valve block and searching for leaks on the front struts...
